I decided after using the search function here a bunch most of the results I am getting are from owners of 00-01 Manual Insights with these issues.
Seems like there are different LAF (o2) sensors available for us different owners.
I have had O'Reilly's pull a p0134 code and AutoZone pull the same P0134 a day or 2 later after resetting the CEL.
* I have come to find what LAF means... Linear Air Fuel, which means its a way more sensitive o2 sensor, which also means lots more money.
P0134 CEL code points to the Upstream LAF sensor. Does anyone have any other suggestions with this code? I already checked my ground cables. All of them are good, I totally believe w 93% certainty.
The correct Honda part for the Upstream LAF is: 36531-PHM-A21 (4 wire) should go into any 02-06 Insight.
From all the reading, I believe a Bosch 15394 could potentially be the replacement. Anyone else with thoughts?
Are there any other choices for this LAF sensor that needs to be 4 wire and not the early version of 5 wire?
For some reason on my note pad I have written down:
Denso 192400-1061 4 wire. This might be the actual Honda labeled part. Can anyone confirm?
Does anyone know what the NTK 24301 will work with?
All these OE suppliers and part numbers have my mind not functioning. Hopefully a few of you can sort all this out before I wake up in the morning.
Thanks in advance!
Thanks in advance!
