I have been thinking for the last couple of years about putting a set of LED lights in the little window on the hatch that lights up and it says "Charging", it would work with a vacuum switch (Hobbs switch).
It would work when you release the gas pedal, as the car starts charging the lights would turn on, but it would also have another circuit so when you touch the brakes, it would light up another set of lights as well, when you come to a complete stop, the engine would turn off, and since it's wired to the vacuum switch, the "Charging" lights would turn off as well.
So picture this, take your foot off the gas, "Charging" turns on, but not too bright, when you step on the brake it would get brighter, it would not affect your regular brake lights.
It would also let the driver behind you the reason you are going so slow, the would be able to see you are charging the batteries, not only would this educate the public, but also get them off your back.
What do you think?
What do you think?
