1 - 3 of 3 Posts
So its been awhile since I was on here, but I have an issue I was wondering if anyone else knew anything about. About 9 months ago, my fob stopped working, about 2 1/2 months ago, my IMA system stopped working; no assist, no regen, and until you put the key in and turned the key, no power locks or anything worked. Now about 2 months ago the car popped up with a check charging system light, then about 10 minutes later it had a battery light, and another half hour or so later I had a christmas tree light situation on my dash(they were all on) I work as a delivery driver and at the time my Insight was my only car, and all this happened while I was at work, so I couldn't just stop. I parked the car and haven't messed with it until now. I drove her today, just around the block to see how it was doing and to get the fluids flowing, so I charged the 12v battery off my mini for about 10 minutes then took it around the block, still no assist or regen, had a battery light, and check IMA and Charging system lights. Now, I thought the Insight could run without the battery pack plugged in or not working, but am I wrong? Is it possible a dead 12v battery is causing the problem and I meed to replace it, or is it likely something involving the battery maintainer and the battery pack all together? 2011 base model with 65k on the clock.
If it has the original 12 volt under hood battery it is time to replace it. Very common for a failing battery to make weird things happen.
1 - 3 of 3 Posts
About this Discussion
2 Participants
insightsport23
Honda Insight Forum
Full Forum Listing
