Hello,
My car has around 90K on it, been smooth riding since i bought it at 60K, now its finally giving me an error.
The code is P2646, from the research I've done, it seems to be that the pressure switch (37240-PHM-003) needs to be changed, or it needs to have more oil(not really sure which oil, but I just took it in to the dealer to get an oil change).
I currently have the switch on order right now, and I did manage to clear the error using my OBD scanner... But if i were to rev over 4K rpm, the same error comes back on, along with some jerking motion (kinda scary driving at high speed).
This car is my only mean of transportation, so today, I took it for a drive to work like usual driving under 4K, nothing showed until 50 miles later, the "maintenance require" light turns on.
My theory is that the oil is low or need a change since last time i took it to the dealer, they told me I need some fluid change, but it were going to cost me $200-300 to do it.
So my question is... What is the real problem? How do i check my transmission fluid? (I only see brake fluid, radiator, orange dip stick (I think it's the engine oil), and another dip stick (No label).
Any help will be greatly appreciated!
