Taking a similar stab in the dark. I would think given the codes you have bad catylitic converters, or maybe it's just a bad sensor. Either way the proper procedure for fixing that is to replace both cat's. I hope your under the 50,000 mile emissions warranty because otherwise the cat's alone run a few grand.
Here's what the ESM says for those codes:
DTC P0420: Catalytic System Efficiency Below Threshold.NOTE: If some of the DTCs listed below are stored at the same time as DTC P0420, troubleshoot those DTCs first, then recheck for DTC P0420.P0137, P0138: Secondary HO2S (Sensor 2)P0141: Secondary HO2S (Sensor 2) Heater1. Do the ECM Reset Procedure.2. Start the engine. Hold the engine at 3,000 rpm (min-1) with no load (in neutral) until the radiator fan comes on.3. Test-drive 64 - 88 km/h (40 - 55 mph) for approx. two minutes. Try to keep the engine speed between 1,500 to 2,500 rpm (min-1). Then decelerate for at least 3 seconds with the throttle completely closed. Then reduce the vehicle speed to 56 km/h (35 mph), and try to hold it until the scan tool indicates catalyst readiness complete. Is the test result FAIL? YES - Check the three way catalytic converter (TWC). If necessary, replace the TWC. n NO - Intermittent failure, system is OK at this time
A search for P1445 turns up nothing in the ESM. Good luck.
