Recently my clutch started making a very light click/tap noise when I released the pedal. The sound is taking place within the passenger compartment. Yesterday, I crawled under the steering wheel and played with the clutch pedal and found that it is leaking some fluid. There is some type of piston/or shaft that is connected to the clutch pedal, then it runs through the firewall. It is about where the piston goes through the firewall that a very small amount of fluid is coming out, then drips down on the wall behinf the pedals.. Has anybody else dealt with this or have any repair tips? Thanks
