Brent at Flamboyant replaced auto trans for me, and maybe a few other things? have call and email into him but nonresponding, Id need to remove dash to get to hvac "module" ??? seems there is a new dash or something cause the odometer is lower 10k now...
can I get to it thru the glovebox cause I kno he repalced the glovebox?
If he replaced the odometer, it means he took the whole section of the dash off where the gauge cluster is and the climate control. That whole section comes off in one big piece. The instructions on how to get to the climate control a few posts ago are very good but missing a bit of info.
1) Unscrew the three screws under the bottom steering column plastic cover then unsnap the top and bottom portions of the steering column plastic colvers and remove the bottom portion only (don't worry about the top part yet).
2) loosen all four 12mm nuts holding the steering column up (back them off so they are nearly off - but not removed - this will allow the steering column to drop enough to work with) Now the top plastic peice of the steering column cover can be removed.
3) Looking at the vent to the right hand side, on the right of that vent there is a small plastic cover that blends in with the shape of the vent. Using some needle nose pliers, pull the plastic panel straight outward (It does not take much force and you don't have to grip the cover very hard so you do not damage it)
4) Remove the screw behind that cover
AND the two screws in the upper portion (in the area that blocks the sun from the gauge cluster - there are two screws in that area - You can see them if you put your head down by the steering wheel then look up to where the sun would block the gauge cluster.)
5) Grab one side of the large panel (I think the far right hand side is easier) then yank forward slightly to break free of the remaining clips that hold the panel in. Work your way from one side to the other and the whole panel will come out.
Now, check around the back of the climate control unit and see if the two connectors are installed properly (if they appear to be - I would still remove them and reseat them again since you did a lot of work to get to them). The connectors are fully seated when you hear them click into place.
While the dash is still in your hands, try the climate control with the ignition turned on (it will not hurt anything even if you disconnected some of the other connectors to get better access).
If it works then put it all back together again in reverse.
If it does not work and based on your earlier post saying the odometer is now 10K less, check to see if you have the correct climate control for your car. They are different based on if you have A/C or not. It may be possible that the gauge cluster and climate control parts got mixed up with another car. I am not sure why those parts were changed but if you now have 10K less on the odometer, I can assure you the instument cluster was changed for some reason (not the ECM) and that would mean that the large panel hold the climate control was set aside and perhaps it got mixed up with another car.
Also, if there was nothing wrong with the gauge cluster in the first place, you should get your old one back because now, if you ever sell your car, you will have to sign the odometer discrepancy and that looks suspiciuos to some potential car buyers.
If you do swap the odometer, based on the instructions above, the whole instrument cluster comes out with just 4 more screws and removing three connectors in the back (for CVT - not sure if MT has another one).
I have removed the whole dash out of both of my Insights several times to fix some rattle here and there and to repaint the dash. Painting the dash while still in the car is nearly impossible to have it look like stock afterwards.
Hopefully that helps.
