Hey everyone
I'm getting a clunking Noise from inside my car. Based on research from insight central I think it's the sway bar going bad but not 100% sure.
I jack standed the car to look underneath and it doesn't look like anything is rubbing or any bolts are loose
The noise only happens on low end acceleration and deceleration . Sounds like the right side of the car as well
I'm hoping someone has heard this sound before and can help diagnose the problem
Link to a video of the sound
You might also check the condition of the "engine" rear motor mount.
Agree rear motor mount would be a good thing to check. The actual noise reminds me of the noise I hear when my steering rack mount bushings are stressed, when steering is torqued full left or right and I go over a bump. Maybe worn sway bar mount bushings/lose loose attachment could do it, too?
2000 Silverstone G1- 200k miles
The difference between a bad mount an and a sway bar linkage is the linkage will be heard over minor undulations and bumps in the road. You'll hear it even going into 30-40mph even. But if it's only on accell and decel, I'd check the rear engine mount.
^ I was thinking the sway bar mount points might make that noise - where the bar goes through a bushing on each side, attached near where the steering rack is attached - rather than it being the linkages...
Discussion Starter · #6 ·
The weird thing is I noticed the noise after I replaced my engine mount a few days ago.
I followed the procedure listed on the forum
And today I double checked my work inspecting the new mount and making sure everything was torqued down correctly.
Took it for another drive and the noise is still there
It's three distinct clicks that only happen on acceleration and deceleration.
Turning doesn't make it happen either.
It feels like something is loose and is shifting with the weight of the car.
It doesn't look like the noise is something serious and it might be something I'll have to live with.
Here are a few pictures if that might help but I know its almost impossible to tell through them XD
Another thing is that the center bolt that goes through the rear mount looked short compared to the online spec's
Automotive tire Auto part Bumper Motor vehicle Gas
Automotive fuel system Automotive tire Motor vehicle Rim Gas
Gas Bicycle fork Font Wood Metal
