clutch
The transmission can be removed from the engine while the engine is in the vehicle. You will have to remove the wheels, the lower mounts to the front struts, lower ball joints, both axle nuts, axles, rear and side motor mounts, etc. Suggest you purchase a Helms manual before you attempt the job. Check the fluid level in the clutch master cyl. reservoir. If it is down near the bottom of the container, the clutch is probably worn out. It's a well built clutch and should be good for over 200,000 miles with proper use.
