1 - 7 of 7 Posts
Hi, first time on this forum so forgive me if this is an old issue that has been discussed before!
I have an error code 12 on my year 2000 cvt, 37,000K's. In the last 6 months it has had a new IMA battery fitted by the Honda dealer, a replacement BCM, MCM and bypass contractor but the fault remains. I have looked into the code 12 fault myself and it seems to be pointing to a circuit failure/incorrect voltage (P0AA7?) in the motor drive module?
I need to get the car going so does anyone know how to fix this? I have run the car with the IMA battery disconnected but I live up a steep narrow hill and the car only has enough grunt to go up it without a passenger (wife not impressed!)
Any help would be great! Thanks.
37,000k is 37 million miles. I think you hold a record for car with the most miles! Contact Guinness book of world record!!
On a serious note, if the battery was just swapped, either something got damaged or they didn't plug something in right.
HV contactor stuck either open or closed. Replace is the only option.
Flash 12= P-1576
HTH
Hi, Sorry, it's 37,000 kilometers. The battery was swapped out about 6 months ago and the car ran fine up until about 5 weeks ago. The car made a buzzing noise and the IMA light came on. I was told that it might be the MCM so I swapped it out but no use. I can start the car normally but after 5 mins of idle there is a noise like a relay clicking and the IMA light comes on. Yesterday I tried it again, same thing so I turned off the ignition, tried again about 2 mins later and the car started on the aux. starter!? IMA light still on.
Where do you live? Maybe one of the IC members who lives close by can help you.
1 - 7 of 7 Posts
