1 - 2 of 2 Posts
Hello all,
I have a 2000 Honda Insight, and i have a couple of questions regarding the replacement of a defunct coil pack
(1). I used an OBD2 reader, and it said that there was intermittent failure over the 2nd cylinder. Which cylinder is the 2nd cylinder? I want to assume that its the center one, but im not sure what the firing order is.
(2). What does the coil pack look like, and where is it located?
coils
#2 cylinder is the middle one. The coil is mounted on top of the sparkplug. You can't see the sparkplug until the coil is removed.Two 10mm bolts (wrench size) hold the coil onto the sparkplug. Unplug the coil, unsrew the bolts and lift the coil out.
1 - 2 of 2 Posts
