Engine/Mechanical:
12V Battery options
(see Modifications and Technical Issues sticky)
12V Starter doesn’t work
How to test the 12V starter
12V Starter doesn't work
Air Conditioning
Guide to installing A/C system
Air Filter
Replacing the air filter
Installing K&N air filter
Who has tried a K&N air filter?
K&N air filters
Alignment
Alignment Question
Ambient Air Temperature Sensor
Relocating the AATS
Brakes
Front Brake Job (Guide)
Front brake guide
How to change front brakes
More info on changing the front brakes
Difference b/t CVT & MT brake pads & suspension
Catalytic Converter Information
Clutch
A Guide on How to Change Your Clutch
Needed: Procedure for Clutch replacement
Replacing the Clutch Slave & Master
Clutch chatter fixed
Grinding in 1st gear (how to drive a manual, how to adjust clutch pedal)
Cooling System/Heating system
Insight Coolant Flow Diagram
Overheating problem (includes "How to bleed/purge cooling system" video)
Thermostat walkthrough
CVT Fluid change
How to replace CVT fluid
CVT fluid change
EGR
EGR plate cleaning
New EGR valve option- 1999 Accord EGR works perfect
EGR valve repair ideas
EGR valve internal repair
I do not recommend cleaning the EGR with WD40
Cleaning the EGR with the help of the 12V battery, and EGR Valve discovery
EGR Valve trick
Modifying EGR for improved economy
Engine mounts
Bad engine mounts, need help
Filled rear motor mount
Replace rear engine mount
Polyurethane engine mounts
EPS -Electric Power Steering
Steering
EPS/Power steering
Exhaust
2001 vs 2004 exhaust (with pictures)
Fuel system (Gas)
How to change fuel pump and fuel gauge sender
Fuel tank capacity?
Gas fumes inside car
Repair leaking fuel lines in engine bay near firewall
Fuel line failure modification
12V Battery options
Air Conditioning
Air Filter
K&N air filters
Alignment
Alignment Question
Relocating the AATS
Brakes
Front brake guide
Clutch
CVT Fluid change
CVT fluid change
EGR
EGR plate cleaning
EGR Valve trick
Engine mounts
Steering
EPS/Power steering
Exhaust
Fuel system (Gas)
Fuel tank capacity?
