1 - 11 of 11 Posts
Hey
I want to buy this cargo for the Honda Insight balance of batteries in 2011. Attached Images.
If the connection to the battery ima I have no problem I have plus and minus and I know where to connect them.
My problem is that with the connection to the fan, the power supply comes out only 2 wires, plus and minus, and my car has three, plus, minus, and signal,
Will the addition of the plus and minus fan work?
Or do I have the controller attached to the picture?
last question.
I realized that this power supply would fit my vehicle apart from a change of connectors. Is there any other problem with the power supply of my vehicle?
Thanks
You should check with the seller. I don't see that they list a charger for the G2 Insight. Don't buy one for another car. The voltage will be wrong.
Hey
The seller says it will fit in terms of voltage.
I enclose a picture of the description of the product.
Thanks
This doesn't list any specs. Did you go to their website? What car was this particular charger designed for?
Hey
This is the product I ordered
ebay.com/itm/331564660401?ul_noapp=true
You can find on the seller's website all the details about this power supply.
rbbatteries.com/information/
Ok. Maybe I'm nuts. I hope it works for you.
The one you bought specifies '00-'06. These cars have a different size battery from the '10-'14. I assume the chargers would be different for the different size batteries. If the seller says it will work I guess he has tested it.
Maybe somebody with more experience than me will chime in. I've only worked on G1s.
RB is a piece of sh!t charger. I know. I have one in pieces under my desk. It's $15 worth of raw materials and 20 minutes of shoddy labor.
You should contact the seller for support, or buy a Hybrid Automotive system that's designed to work with your vehicle.
I can promise you the charger you ordered won't work on your car.
Discussion Starter #10
Hey
I'd love to understand more
The cargo of this hybridautomotive company
Provides 350mah.
For my battery like 0-128 volts.
Honda's first generation battery is between 0-180 volts.
My battery is only 84 cells.
Why should not the first-generation charger work?
It can provide more volts to a battery of 120 cells.
Thanks.
1 - 11 of 11 Posts
