It's been about a year and a half since I installed what I said would be the last Insight NiMH pack I'd work on/with, having gotten tired of it all. But, this original pack in its reconditioned state has been working awfully well and has been producing some surprising results. It works in ways that I never thought possible with Insight NiMH. That's mainly why I'm here, one particular aspect, that makes we wonder about the car's stock management and the way the pack - a good pack - should actually perform...
It's all kind of complicated so I'll try to stay as focused as possible on only the 'main thing'. That main thing is this: I can use the pack at what seems like an historically low state of charge, get full assist, and have voltage remain high and stable despite that low state of charge, cool temps, and relatively high assist discharge... This, plus what I've seemingly done to achieve this, plus what appears to be improvement over time/usage, makes me seriously question whether the stock pack management has a major flaw, a flaw that causes deterioration...
In a nut shell, I finagle pack management with the OBDIIC&C and calpod clutch switch, basically forcing usage of the pack in a relatively low charge state. This has allowed me to get a better read on what happens 'down there'. You gotta do this 'finagling' most of the time, otherwise, the car will background charge and such and keep the pack at a higher charge state.
The thing is, if you do this, the pack - my pack, at least - will fairly quickly... 'acclimate' at the lower charge state and it will start looking and performing just as it does at the higher charge state... I'm mainly talking about voltage. If you start at a high-ish charge state and discharge (use assist) for a long stretch, pack voltage will drop and stay pretty low, say around 152V instead of around 161V. The car will background charge. But, if you purposely try to use the pack in that low charge state, doing assist and regen around say 40% state of charge, the voltage will fairly quickly come back up - it will gravitate toward about 161V, not that lower 152V level that it started at...
Say you discharge from 70% to 45%. Pack starts at 164V at rest and ends at 152V at rest. The car tries to background charge but you hit your calpod switch instead, preventing it. You purposely use the pack at around 40% to 50% for a few up-down cycles. Soon, pack voltage will pop back up to around 161V - at that 45% charge state - not the 152V you started at...
Now this, I think, is the crux of the potential stock mismanagement. It appears that background charging at least sometimes responds to voltage, most likely tap voltage. The problem with this, it seems, is that there's too much 'hysteresis' in the voltage behavior... It seems pretty clear that if I force pack usage at progressively lower charge states, letting voltage 'acclimate'/adjust or whatever each time, background charging won't kick in as soon and/or as often as it otherwise would. It really looks like the car is using tap voltage at least in part to decide when to background charge: on the first cycle down, say to 45%, voltage will drop low, the car tries to background charge, I stop it with the calpod. I use the pack around the 40% level and voltage pops up. After voltage pops back up, the car doesn't try to background charge as often... But that wouldn't happen if I didn't manually, purposely manipulate the car with the calpod, turning off the background charge and using the pack at a low charge state. Rather, the car would see the first low-ish voltage, the low-ish voltage on the first cycle down, and immediately start to background charge, charging until say 70% nominal. And it will keep doing this over and over, never letting the pack get used in even modestly low charge states...
The stock management appears to charge too much, too often, keeping charge state too high too much. I think this ends up 'crudding up' the lower charge states, makes them even less usable - higher resistance, voltage depression, whatever you want to call it.
I'm seeing something like 144-145V at about 20-25 amp discharge, at 62F, at around 40% state of charge. I can also invoke full assist and get it - somewhere around 70-80 amps at 125V, with these conditions... I used to think the BCM charged the pack to around 70-75% because the pack could only perform well, like put out full assist, when the pack was charged above say 60%. I don't see it that way at all, now... Being able to use the pack like the numbers above describe, to me used to be unheard of, it was impossible.
If you've ever seen discharge curves (voltage vs. time or capacity) for Insight NiMH cells, good ones are really quite flat over most of the discharge, while bad ones, mainly ones that have whatever kind of voltage depression/memory effect, crud, whatever, will crater early on, typically well before the mid point. It's this area of the capacity - the area between the mid point and the end - that, over time, gets used less and less in the Insight. And I think it's a negative feedback loop, too: the less this area gets used, the more deteriorated it becomes - and the less it will be used on the next iteration, and so on. But, I think, if you force usage at low charge states, I think it might keep the 'curve' high, keep it from cratering early. And then, the car allows usage of that area on its own more and more. To a point, at least (I think there's hard-coded behaviors, like fixed charge state percentages, that trigger stuff. For instance, at about 38% nominal, I don't think you get as much assist, regardless of voltage)...
