That's a great scope! My daily driver at NI was a 2 GHz ABW Tek DPO. Whenever we needed more bandwidth we'd typically just rent test equipment.I do now.
Tektronix DPO7104, 1GHz bandwidth and 20GS/s. Used eBay scopes are awesome, this was about 1/5 the price of an equivalent modern scope. It won't perform as well as a new scope of the same caliber, but it still has excellent specifications and features.
Each active probe I used at NI cost more than the entire scope setup I use now. Honestly the real-world analog performance is almost entirely a function of your input probes.I'm just waiting on some 500MHz passive probes, a 1GHz active probe, and a 30A, 120MHz current probe to arrive. All also secondhand off eBay for 1/4 price or less.
Are you using the base firmware you previously wrote for the old hardware?For Pegasus, I've been slowly performing various tests that will make sure every functional aspect of the board is working properly. Then I will start writing the bootloader, then finally the firmware!
I already have 40-50 various changes I want to make, but nothing too major. So far everything has been working great, for the most part!
IIRC, previously Pegasus was powered from the +12V rail on the OBDII port? Why the change? Does the new power harness require soldering?I also installed the power harness (required) and the signal harness (optional) in my test cluster, of course to test that functionality as well.
