Controlling the Instrument Cluster's Display
74946 Views 470 Replies 65 Participants Last post by  Mario
A little project I'm working on. :) (Sorry for the horrid picture!)
Here's the elevator pitch: Directly control the LCD panel with a microcontroller to display custom information on the instrument cluster. The microcontroller will also read the data that would normally be going to the LCD and can choose to display that info or custom info.
Maybe you want to display OBDII parameters where the MPG is. Maybe you want to change the charge, assist, and SOC gauges to accurately reflect amps in/out, real battery SOC, etc.
I've got a few other ideas as well. Once I'm finished with this project I'll open-source everything I've learned and perhaps produce some PCBs to sell. We'll see!
I have work and other projects as well, so it may be slow going at times. But I'll try to give updates fairly regularly.
I don't think this has ever been done before. I hope you guys are excited!
If anybody is or wants to work on something similar, I'll be glad to share what I know; just ask.
See less See more
  • Like
Reactions: 5
161 - 180 of 471 Posts
Figured I'd give a quick update on the state of the code. I've been working casually on it and have gotten a lot done since the most recent demonstration video (https://www.youtube.com/watch?v=OXi7dnEgSMg). Also been squashing various bugs.
You can configure 16 different parameters to show in the MPG area (as demonstrated in that video), but it's now possible to configure the gauges as well and to show things on what I'm calling the "FCD numbers" - the 50, 100, and 150 above the instantaneous MPG gauge. There's a menu system to configure all these that I think is pretty simple after a quick explanation. I tried to make it as intuitive as possible, given the limited display capabilities.
I have a Pegasus board installed in my Insight, of course, so I can test it every day. When I have new firmware to put on it I can just upload it over the USB cable that I left hanging out by the OBD-II port. Very useful!
I currently have Pegasus set up like this - autostop light shows whether I'm in lean burn or not. Fuel gauge shows TPS, 0-100%. Battery gauge shows actual SOC, 20-80%. Assist/regen gauges show IKW (IMA request in kilowatts), 0.0-9.0kW. On the FCD 50/100 I'm showing assist/regen limit flags (those are just 0 or 1). And on the FCD 150 I'm showing instantaneous MPG, calculated from RPM, speed, and fuel injector time as discussed before.
I have gotten the instantaneous fuel equation to be pretty good - I'm assuming 145cc/min and it seems accurate up to about 110mpg, but higher than that and the number I calculate is higher than what the bar graph seems to show. I may need to tweak it a little still.
It's coming along quite well! Still a lot of features to implement for what I would call v1 of the software, but it's going well.
See less See more
That is so impressive and cool!!!
Your dedication and retro-cool creativity are inspiring...
Fuel Gauge
For my proposed Insight EV conversion using Linsight controlled quad stacked IMA motors, would it be possible to modify the existing fuel gauge to read available (remaining) battery capacity and for the SOC gauge to read ongoing volt amp input?
Definitely, as long as they are parameters that Linsight will have available to read over the H-Line (pretty sure it will have those).
Yes, those parameters will be supported.
A quick update to say... there are no updates. I've had this project on hold for a bit while I'm working on a small side project I've wanted to do for a long time. Unfortunately, it's taking slightly longer than expected.
But rest assured it's not dead, and Pegasus will be completed at some point in the not-horribly-distant future. :)
Any idea on a price yet? The talk in the Linsight thread has me interested.
I'm excited to get my hands on one.
Probably $250-$300. The parts, PCBs, assembly, etc will probably be $150 or so. And then I need to make a couple cables (stripping and crimping connectors), which takes some of my time. And a little on top for profit. We'll see about what it comes out to once it's done.
Ok... sounds good. Thanks!
Mario, just to let you know- I approve of this activity.
:D
Count me WAY in
Who would like a prototype Pegasus system?
Read the whole post first, please!
It is not first-come-first serve, so no need to rush to send me a message. The prototype boards won't be ready for another month or maybe two.
Now that I have your attention... :) (don't get your hopes up, there is only one available at the moment)
Work on Pegasus is coming along, albeit slowly because I've been splitting my time among several projects, but it is coming along!
In the meantime, I've been using Pegasus every day in my car and I have it set up how I like, and it just seems second-nature to me now. But I realized I should be having other people test it, too - that way I can find more bugs, see what features people really want, and be more motivated to work on it because people other than me will be using it.
So I'm putting together a quick second revision of the PCB that implements a few fixes for problems I found on the first one, and will be making five prototypes.
Two of them I have offered to a couple members personally because I'd prefer they use it. One I'm offering up here. The remaining two I'll be keeping - one to put in my car, and one to develop the code on.
Here are the requirements, in order of most to least important:
- Already have an OBDIIC&C and use it often (it's not required for Pegasus to work, but I want somebody who is interested in these sorts of systems/extra info)
- Be willing to give good feedback. I want feedback on ideas for new features, how Pegasus could be improved or made easier to use, any bugs found, etc.
- Have a UK car. I have a US car, so I've done plenty of testing there, but I want testing in UK cars as well.
- Have a CVT (same reason as above)
To install Pegasus, you'll need to take apart your dashboard. It involves dropping the steering wheel, pulling off the trim, and taking out the instrument cluster. It's not too bad, the entire install will probably take you two hours if you've never done it before.
As a reward for helping, you can keep the whole system, free of charge. It is possible the hardware may change enough later that future versions of the firmware may become incompatible, so no promises about long-term support... but hey, it's free, right?
If you'd like to apply, send me a private message.
Edit: To clarify, you don't need to meet every requirement to apply. But the more requirements you meet, the more likely you are to be chosen. Really, the only one I'll actually require is that you be willing to give good feedback, because the whole exercise is pointless if I don't get any test data back. :)
See less See more
2
Revision 2 of the PCB sent out for fabrication! :)
It'll still be a while yet before prototype rev2 units are ready, though, because I still need to make the cables, joystick boards, etc. Gotta find a source for some OBD-II plugs, as well.
It may not look like it, but this version is much simplified and cleaned up. It uses fewer components and I've consolidated some stuff and gotten rid of other things.
I've changed user GPIO so there are 4 ports, all the same, each with 12V, 5V, and an I/O pin. The I/O pin has the ability to read analog/digital values in and also output a low signal so you can drive 12V relays, lamps, etc. There is also the capability for UART communication on one of them for future expansions. I have a couple ideas in mind for what could plug into that. :)
I've added a button for test functionality - this allows you to, before even taking apart your dashboard, test the whole Pegasus system and make sure it can communicate with the car, joystick, etc and that everything is working fine.
For the user GPIO, you can draw up to about 1.5A on the 12V and 5V rails combined. Those are both powered from the OBD-II port and includes a polyfuse in case you short something out.
I still need to design a tiny joystick PCB, but that'll be fast and easy. I'll also model and 3D-print some new expansion covers (the little plastic plugs next to the driver inside the car) that have mounts for this PCB so it's a quick and easy installation.
See less See more
Nice work. How big is this? Does it not mount inside the instrument panel?
nice random dolphin, lol
Mario:
Amazon.com has numerous OBD port cables in different configurations and lengths listed.
HTH
Nice job.
As you are elbows deep into the cluster perhaps you can comment on this.
Is the oem cpu firmware likely to be readable?
(Assuming they have not set the fuses in the cpu to block downloading)
i.e. Could we download the firmware from a UK gauge for instance and load it into a US one.
Can we add the mph/kmh switch to gauges that don't have it.
Does it do anything in that case?
I'm thinking about swapability between gauges and as there are quite a few cluster in US scrapyards perhaps turning a few of those into to UK/EU ones..
Ah, sorry, I was talking about the small joystick PCB. The main PCB (shown above) goes in the instrument cluster.
Mario:
HTH
Thanks Willie, I'll see what they have.
Nice job.
You may be able to read the firmware back, however, I believe the memory in the microcontroller on the cluster is one-time-programmable. You can't put new firmware on it once it's been programmed. Best you could do is swap the chip from one cluster to the other - but at that point, it may be better to just swap the whole PCB or even the whole cluster. :)
It may also be possible that the firmwares are the same on all the clusters, and there is a jumper somewhere to select different configurations. I find this unlikely, though.
Not sure about the mph/kmh button - I don't have one of those clusters, so I haven't tried it! Anybody have a spare Japanese cluster they'd be willing to sell?
