Depends:
Distance traveled after fluid change.
Driving style after fluid change.
Way back when and AFAI remember Honda had authorized on a limited basis substituting ATF for the then specified 10W-30,40 engine oil in MT's. There were a _few_ slight "whines" that were "cured" by the different properties of the ATF.
The _biggest_ problem with ATF vs. engine oil (or now Honda's special MTF blend) is its shear strength and the differential pinion gears. If you spin one wheel these gears must "walk" _very_ rapidly on the side gears (in the differential). These oil shearing forces can _rapidly_ cause lubrication failure, gears seizing to the pinion shaft and total transmission failure as this pin slings out of its housing and grinds a hole in the case.
Shaft bearings only :?: Not likely. Sorry I know its not what you want to hear.
HTH!
HTH!
