Hi I have a 2000 insight I've been driving for two years with the IMA disabled. Its never given me any problems (other than ones I've created) but yesterday it tossed me a head-scratcher. The car was running fine when I drove it an hour home on the highway before Christmas, and its been sitting in moderate-cold weather since then for 4 days.
When I turn the key the starter spins the engine and all the belts turn but theres no combustion. I tried a few time and it won't even cough.
So no combustion, has to be fuel or spark, right? I check the easiest thing first by spraying ether into the intake. I try several times; no effect. (I was spraying it into the tube that connects the throttle to the air filter, so the air filter wouldn't block it.)
So if theres no ignition with starting fluid then it has to be spark, right? I pull one of the coils out and have someone else crank the car while I test the coil with an old spark plug. I tested two coils and both made sparks like normal.
Is there something that could be blocking the ether from getting into the cylinders? I checked the throttle valve and it opens just fine. I'm not sure how the ether could not burn if theres spark in the cylinder, unless the ether isn't actually getting into the cylinder.
