Creep noise Gen2 - Front brake pads after replacement.
220 Views 3 Replies 2 Participants Last post by  andrewassurance83
So I finished a full brake job last month (including new brake calipers, Rotors and Pads). But I have a creep noise after slightly releasing or pressing the brake...
I am wondering which brake pads do you use? I have currently the Bosch and probably continue to use them until they worn but would not bad to know for the next time.
I use OEM pads. Did you check and clean the brake slides (clips)?
Yes I used new sets of slides and changed all 4 brake calipers. It's not very loud but it's a bit annoying when I do a complete stop.
Did you prep the brake pads and rotors upon installing them?
