I installed mine also. Worked for a couple of weeks before it quit. I got a replacement unit but it still didn't work. I tried reconnecting everything but still no luck. What kind of connectors did you use? I used the standard tap-in blue ones. For power, I used the fuse box brass tap-ins that are put on the prong of the fuse and then push back in the fuse. It was extremely confining at the computer but I thought I connected that wire ok. Do you have any photos of your connection work? I don't know what type of place could even troublshoot the problem.Valiant118 said:Thanks for the update. I installed one myself two weeks ago and am very pleased with it. I installed quite a few of these back in the day on VWs, this kit is much better than most aftermarket units I've experienced.
