I was asked by a member of the Facebook Insight group about the rings to mount the rear speakers so I made this mockup last night. It seems to fit first try, but does anyone with more knowledge of these parts have suggestions for improvements? Are there different mounting patterns with different speakers? Do people trim the original parts for any reason? Is there a specific area that easily breaks? Thanks!
At the suggestion of another member, increased the diameter of the cavity to 6.9" and added standard mounting holes for 6.5" and 6.75" speakers. I will be designing two variants - A standard, and a deep version.
At the suggestion of another member, increased the diameter of the cavity to 6.9" and added standard mounting holes for 6.5" and 6.75" speakers. I will be designing two variants - A standard, and a deep version. View attachment 97260
AfterEffect. Would it be possible to 3D scan the cluster bezel? I understand it's a large piece, but they are getting broken more and more now, and not to mention unobtanium in the junkyard because everyone breaks them there as well.
[Edit]: Even if, as of right now, nobody has the ability to print it, at least the information will be out there and accessable in the future.
I'd be happy to scan pne but I'm hesitant to remove my own and risk breaking it. My Insight is my daily driver, and I have few extra parts. I'm in the Seattle WA area, and if there is someone that would allow me to borrow one for a day I would gladly scan it. Otherwise I can look for one the next time an Insight comes up in a local wrecking yard.
I should also mention that larger objects are actually easier to scan. The scanner doesn't do well with smaller, more complex items so that trim piece is a good use-case. Printing it would be time consuming but not impossible. Probably 3-4 days of solid print time for something of that size. Of course there is also the design work needed to take a scan and rebuild it into a usable piece.
An alternative would be to take a good piece and cast it in urethane resin. It would be several hundred dollars in materials to make a fiberglass and silicone mold and pull castings from that though. Could you send some detailed photos of the part?
Edit: Image of a scanned door panel requested by another user as another example of scanning a larger piece. I oversimplified this mesh, so it could be better.
If 3D scanning is happening, I BEG somebody to do the sail panels. They snap on/off easily, are the parts above the door panels, front of the windows, black plastic parts. I really want to print some with tweeter pods built-in.
I'm happy to scan pretty much any part for other Insight owners. The more I think about it, it could be a good way to "catalog" parts that will eventually be unobtainable. Do you have the skills to use a rough scanned mesh and convert/modify it into a solid/printable file?
This is a raw scan of the LH (Driver side) sail panel from a 2001 Insight. It should fit 00-06 models. It will need cleanup of the tabs before printing.
whoa thats awesome. id need a set. i was about to pay someone $150 for oem ones.
and the fact you can make them fit bigger speakers is a big plus. but wonder how they fit since behind the passenger side the ducting for the battery is there.
That's insane, is that how much those are worth now?
I can design a cutout in the ring to avoid the ducting on the passenger side, however I'm not sure what speakers would fit. I will be getting some additional clearance by making the bezel slightly larger and pushing the whole trim ring forwards, so it will stick out further from the panel. Knowing what speakers people want to use/are using would be helpful.
crutchfield.com does a good job of fitment verification.
That should get you some dimensions.
I would lvoe to see some buckets to mount the front speakers to the door, rather than the rattling door panel that kills all the bass and midrange response.
My JBL GX602 speakers sounded fan freaking tastic inside my Sonata, and sound worst than cheap laptop speakers in the Insight.
Sealing edges and foaming the panel to the door skin made a massive difference in sound quality.
There are three screws right around that area, so cutting out that part of the door panel and designing a mount that attaches directly to the door would be relatively simple. Before I go off on another tangent I need to finish these rear mounts and my double DIN project though.
I'm taking a step back from this project to focus on the double-DIN console design. As promised, here is the file for the mounting rings. This is a nearly direct copy of the OEM piece, and has no modifications for deeper speakers etc (yet). I plan to revisit this once my console is finished.
This is a replacement rear speaker ring that fits the first-generation Honda Insight (2000-2006). Originals are rare so this was designed to bolt into the existing space and snap fit with the Honda speaker grills.
After owning this 2002 Insight for 20+ years I learn there are dummy speakers built in with wiring. I had already swapped out the OEM door speakers and lived with the slightly less tinny speakers. Here is the problem, the OEM speakers have 3 mounting holes, the new Pioneer speakers have 4 holes but that matters not with the trim that apparently just snapped on rather than needing screws to hold the face plate trim on. Now I have the original door OEM speakers in the rear spaces. I have the previously unused Pioneer front face plates over these OEM rear speakers but now the holes matter.
Do I drill additional holes in the OEM speakers? Do I search for the non-existent 2002 OEM grey rear trim kit? I saw the trim kit may exist for 2004 but only in tan, not grey. Or, do I get something fabricated or very close that looks good.
I would consider printing and selling these if there is interest, or potentially casting modified copies of originals in urethane. Otherwise, if you have access to a 3D printer you're welcome to print your own for free.
