Hey All.
Been searching and searching and seems like there are various posts regarding the amount of CVT ATF that's needed for a change. Anyone know for sure the amount needed? Been reading 3 qts is enough while another says you may need as much as 6 qts for a change.
Also, anyone have pics/locations of the drain plug and fill area? Threads I've searched seem to have foggy descriptions.
I was billed for 3 (quarts, I assume)
Hello,
We just had a the major maintenance package performed on our new
2003 CVT (purchased with 82,000 miles). I didn't have any maintenance
records so I figured it best to have everything possible done.
On the invoice under "parts" it says:
QTY: 3 FP-NUMBER: 08200-9001 DESCRIPTION: FLUID ATF-Z1 UNIT PRICE: 6.13
To me, this suggests 3 quarts since the price is about what you see in advertisements for quart bottles.
Years ago I used to work at a car dealership and there was a mechanic who
pretty much spent his time taking apart automatic transmissions, flushing out the gunk, and putting them back together. He told me he'd be out of
a job if people changed the fluid when they were supposed to.
Somewhere on this forum there is a link to an online copy of the owners manual, which has some information on fluid capacities.
regards,
Gene
Re: I was billed for 3 (quarts, I assume)
[quote
[/quote]
That is standard Honda ATF fluid, NOT the Honda CVT fluid which is specifically for Honda CVT transmissions. It is still acceptable though.
Hey all, thought I'd just chime in after the change. The bolt took quite a bit of oomph to get off. In fact I had to kick my socket wrench to even get it to budge! :( The magnet on the bolt had a coating of fine metal shavings which I cleaned off. Probably should have changed the fluid sooner (hopefully no long term damage. :/). My Insight is slightly over 41K miles. Normal schedule is 45K I believe.
To sum it up, a CVT change it's more than 3 qts ($8.44/qt). After 3, the dipstick showed the fluid just to be barly touching the lower dot of the dipstick. Seems like you'll need somewhere between 3-4 qts to get it full.
Also, I couldn't for the foggy find where you can pour the CVT fluid in. After a good 15 minutes of searching, just poured the three quarts I had in via the dip stick hole. Anyone have a picture to show where it is?
Considering doing another another change at 60K. Was scary to see the coat of fine metal particles on the magnetized drain bolt.
Thanks for the feedback Braxus. Hopefully that will help someone else in future.
The dipstick area is the only place to pour the fluid into so you were correct in your decision :D
