Thanks to forum members, I was able to keep from being ripped off for a rebuilat transmission when the real failure was the flywheel.
Two different shops (one of them was a dealer and shame on them) diagonsed the problem as the CVT and said i needed a new one.
In the end, thanks to the forum, I was able to make progress, and the car is at a dealer now and the flywheel is being replaced (same dealer that told me I needed a new transmission.. Call to Honda America I think helped me get this moving in the right direction.
Anyway, the forum pointed me to the flywheel.
The symptom one member reported was that when he started off one day, he hear a snap, and the car went dead. No transmission fault codes were reported.
In his case, investigation showed the failure to be the splines inside the flywheel that mate to the output shaft on the transmission.
My symptom was a bit different. I to, had no fault codes, and prior to, and during the failure, made no snapping or rumbling sounds. Was working perfectly.
I stopped at a light, and when I started to roll, I could feel the start clutch engage, but at about 2 or 3 MPH, it sounded like the clutch was slipping.
I could feel the CVT shifting, but it was also jerking at steady speed, and when decelerating, I was not getting a charge on the battery monitor.
When the dealer let me look at the flywheel they removed (and they did indeed say that the failure was the flywheel), I was surprised when a prove with my fingertip resulted in not feeling any damage to the splines inside the flywheel.
The Tech told me that the dual flywheel has some material between the disks and that this materail can fail, and the result is that the flywheel faces will slip against one another.
There was the appearance of a ring where grease came out from the seal. The spline condition is apperenty caused by improper lub, but in my case again, the spines were fine.. But the Tech said that this ring of grease or whatever it was indicated the kind of failure where the flywheel faces slip.
Now, I don't know if this is true, but is sure matches my symptom... Behaves like a slipping clutch, no fault codes displayed.
Just wanted to share this failure mode with people here so that if you encouter it, you will know that it is a good chance that the flywheel has failed.
I am having them put in a new start clutch (it was worn, and it did seem reasonable to do it even though I am going to sell the car in all likelyhood. Knowing it was worn thin would have made me feel like I was cheating someone when I sold the car, and for the extra $600, I have the peice of mind that this high wear item will not fail for the new buyer).
This hole ordeal has left me with a very bitter taste in my mouth though. While the common conception that transmission shops sometimes cheat people, I left the dealer feeling as if they tried to cheat me by saying I needed a $4800 transmission (and of course they were going to make me a great deal on the trade-in....).
If someone out there has a CVT though, we know that there are two symptoms that can result in no-go condition. The "Total" failure (Loud pop or snap, no fault codes) and the "Slipping" failure (feel the start clutch engage, but starts to slip at 2/4 MPH).
My advice is not to let anyone sell you a remanufactured CVT if you have any of these symptoms with no fault code until you check the flywheel itself.
Good news for me was that all other visible components appeard in excellent condition.
Hope this prevents someone from being ripped off one day.
And just to be clear. I do not know if the dealer lied to me. I am not calling it that. But that is the way I feel. Clearly, the tech that I worked with was famalier with this kind of failure so why I was told I needed a new transmission on the first trip is a "Mystery."
