1 - 10 of 10 Posts
· Administrator
Where is it leaking from?
Joint or cracked etc etc
Take it out and try and repair it?
Sealant etc
Junkyard for a replacement if no one has new...
2000 Honda Insight
I recall reading a thread about another Honda (or was it Acura?) module being usable in our tanks.
insight 2006 MT insight 2005 MT
From what I remember the equivalents that were found were all for the insight 2000-2005, they have two hoses that plug into it
The one you have is a 2006.
I believe that if you need to replace it there is only this solution
2002 silver insight cvt
Sealant etc
Leaking from hair line crack in picture that I circled. Aka the fitting that plugs in. I’d prefer to replaced if possible. Used would be second option tho age is want causes this.
Discussion Starter · #6 ·
It looks like my pump. From what I read all cvt are returnless (one fitting) manual are return. Tanks are different between cvt and manual. But the 06 you listed looks like it works. Idk what makes 06 different.
1 - 10 of 10 Posts
