Help. I have a 2001 insight with 110,000 miles on it. I've never had any problems until recently.
When I'm in PARK and I rev my engine, the engine sounds normal.
When I'm in NEUTRAL and I rev the engine (not in motion), the engine sounds normal.
When I shift into DRIVE, I get a knocking noise.
As I accelerate, the knocking sound gets faster.
When I shift from DRIVE to NEUTRAL while the car is in motion, the knocking noise is still there. The knocking sound goes away when the car slows to a stop.
The car can still accelerate to 100 mph without any problems except for the knocking noise. At that speed the knocking noise sounds like a fast snare drum instrument.
I took it to the Honda dealer (Concord, Ca) and they said it was a transmission problem. They said the only solution was to replace the Transmission which would cost about $4000. They also said I could continue to drive the car until the transmission failed and then bring the car in to have the transmission replaced.
I've had all my maintenance done at this Honda dealer (including transmission oil change)
For a second opinion I when to Arts Automotive in Albany, Ca and they test drove the car to see if they could diagnose the problem (they specialize in hybrid repair). They said they would have to take apart the transmission to see what the problem was. They said if it was repairable they would fix it. The cost to take apart my transmission and put it together was $1500. Additional cost for repair parts would be added as needed.
I don't know where to go for a 3rd opinion. I was also reading through the forum and thought of changing the transmission oil myself.
Does anyone have an idea what my problem might be.
