In 10/2022 I was coming up on 100K and some messages came on for service. I hadn't had time to get it to the shop Due to the whole I have to go to work thing and get time off.
then driving to work on day - I felt the care stutter and hesitate on the interstate and then next thing I knew the engine light came on, I lost most of my rpms, had to quickly pull over and was stranded on the side of the road.
I had the shop come get the car and this is what they found:
1. All plugs burned up
2. Valves out of adjustment
3. Two coils bad
They Replaced all the spark plugs and coil boots
Replaced front/rear ignition coil
replaced iridium/platinum plug
Adjusted the valves
replaced Int. manifold set
And changed Valve cover gasket set
The same day I picked this car up and drove into town - the car engine light came on and blinked non-stop. I lost my RPMS and had to pull over on the interstate. I turned it off and turned it back on- the engine light went out. I took it back to the shop the same day and they said they needed to adjust the timing.
Since that day intermittently when I drive the car I will hear what sounds like a tapping sound and I feel the car stuttering, if I let up on the gas most of the time it straightens out. A couple of times it has happened where I lose my RPMs and can not get above 25mph and then engine light comes and blinks. In these instances when I pull off the road and turn the engine off and then back on again the engine light goes out and it works fine.
I took it to the Honda dealer and was told that the codes clear when you turn the engine off so we can't see anything wrong with it- that adventure cost me $160 to learn that. He told me you have to leave the car running and have a tow truck bring you in. I went out and bought a "BlueDriver Pro OBD2 Car Diagnostic Scan tool and have had it plugged in and waiting for this to happen again.
It finally happened again and I scanned the car with my Blue Driver device. The codes it gave me:
1. P0302 Cylinder 2 Misfire Detected
2. P0303 Cylinder 3 Misfire Detected
3. P0300 Random/Multiple cylinder misfire detected- blue driver says
I took it back to the shop that made the initial repairs today and they told me they can't do anything until they can read the codes.
According to the video series on blue driver when this happens intermittently the coils have to be checked while the car is running.
If a coil is unplugged and the engine stumbles it is not that coil.
If a coil is unplugged and the engine does not stumble it that that coil that is defective. ---then they said to check the coil with a multi-meter.
I do not think this morning they bothered to do the above things, but before I bring it back again I want to make sure that is the correct way to trouble shoot.
Thanks
Christine Conrad ( Frustrated beyond Belief)
3. Two coils bad
Adjusted the valves
Thanks
