1 - 3 of 3 Posts
Walking up to my 2011 Insight, I noticed when unlocking the doors that the driver's side DRL didn't flash like other side, so I assumed it was burned out.
Started engine, disengaged parking brake and DRL on both sides illuminated.
Likewise, I turned on headlights and hi beams, and both sides illuminated.
Turned off engine and lights, removed key and locked car - driver's side DRL didn't flash.
So what's up with that? Clearly the bulb isn't bad because it works under normal operation.
I've noticed similar behavior in my 2010 Insight LX. When I lock/unlock the doors, only one of the two license plate lights flashes. I thought a bulb was burned out, so I bought replacements. But when I turned on the low-beam lights, I saw that both license plate lights were on. Curious...
I have a 2010 Insight as well and have had the same issue since I bought the car (about 3 years ago). I replaced the bulbs but it still happens, even though my headlights work just fine.
1 - 3 of 3 Posts
