1 - 2 of 2 Posts
Hello,
I'm new to this forum and a happy 2010 Insight owner. My car is showing the "Check DRL" error and so I need to replace my driver's side Daytime Running Light. I saw one video that says I have to remove the bumper.
Is there an easier way to get to the bulb and replace it?
Thanks!
DRL bulb removal
The bulb is in a plastic socket that twists out after unclipping the (red?) connector. There is a tab you squeeze on the bulb connector to unlatch it so it can be pulled off. Don’t know if you have to buy the bulb and socket or if the bulb is removable. I replaced both whole headlamp assemblies on my 2010 Insight (fogged/hazed inside) which required bumper removal, but all four bulbs in the assembly can be replaced from the back side of the assembly under the hood.
1 - 2 of 2 Posts
