I'd like to install a deck that I have from another car, but I can't figure out how to remove the stock deck. Most factory decks that I've seen have holes that you poke little rods into to release these clips that hold the deck in. On my Insight I don't see anything like that and I don't see any obvious method of removing the stereo. I've searched the forums and found a lot of threads detailing the results people got from installing new stereo systems but little information on how to remove the factory deck.
Also, is there a wiring harness adapter available for the Insight so I won't have to cut the harness to splice wires onto it? I've seen these for some cars, but I don't know if one would be available for the Insight as it is not a common car. However, it is possible that it would use the harness adapter from a different car, as stereo wiring harness plugs probrably wouldn't vary by a lot.
