Hi all.
I had started testing my circuit for discharging my pack as it is a pain in the butt to keep watching this thing, changing bulb's etc.
I am using 6 x 100 watt, 10 Ohm power resistor wire wound aluminum housed in series bolted onto a heat sink for the first phase of the discharge then 5 x 100 watt, 100 Ohm power resistor wire wound aluminum housed in series for the second phase also bolted onto a heat sink.
The design is a s follows:
If the voltage is above 140 volts it will begin the discharge cycle at 2.5 amps or 375 watts until it reaches 120 volts. Then the second discharge circuit will kick in at .25 amps or 29 watts till it reaches 70 volts. Then the 350ma charger will charge till 160 volts. At this point the discharge cycle will start again.
If it is below 140 volts when connected, it will charge to 160 volts then start the discharge. You can cycle it as many times as you wish.
Have a heat problem though. Those heat sinks get up to 110 degrees C, even with a 55 CFM fan on the first discharge cycle. Second cycle seems to be OK.
I am going to change the wiring connector from those ones on you find on eBay as I find those a little dangerous to say the least, if you use this please change yours too. They use 3 amps on the first cycle so I would rather use something rated for the draw and a screw on type for safety.
I would like to publish this to the community when I am finished so any input would be appreciated.
