just for giggles i shoe-horned my old honda accord rims and tires on the G1 today. they are some cheapo dual lug pattern rims i found on marketplace and they measure 16x7, they are wrapped with 205/50-16 firestones. from what i see this is about as big and wide as you can go with rear skirts without additional mods. 1.6" taller, 1.6" wider, .2" less sidewall, 5.1" more circumference, 61 less revs per mile. the rears clear the swing arm by a 1/4". when reinstalled the skirt, the rear most sidewall tickled it. 2 tugs on the aluminum mounting flange gave me a 1/4" gap on the spat/sidewall.
I road tested it on some washboard/pothole gravel roads and the ugliest tar road around here. made sure to go full bump several times even while cornering to try and get some rub and nothin, nada, all bueno. i should mention my car has stock springs and and all the weight of the ima and spare tire plus 40 pounds of random junk in the trunk plus 170 pounds of driver and 95 pounds of copilot test dog in the passenger seat. i do have very weak shocks and struts with 240k on the car and they look original spec, most roads in northern minnesota are horrible with our freeze/thaw cycles.
My car falls into the very uncomfortable to drive scenario with bad shocks, bad roads and repeated jack hammering on the spine. i prolly look hazardous to other traffic because of constantly dodging small road features that a typical sedan would laugh at. the big tire setup made a night and day difference on the ride quality. one big take away is the stupid number on the dash. i will have to figure my mpg by hand at the pump like the good old days. using my gps, the speedo/odo is 7.5% under actual, i cross referenced with an online tire size calculator and it says the discrepency is 7.6% basically spot on if you factor *10k/mi. of treadwear.
My stock tires weighed 88 pounds, new ones weigh 134 pounds. first gear feels correct in my opinion now, where before was too short feeling, second gear gets me up to our state speed limit and 4th feels like 5th did. i prolly wont need 5th near as often with 7.5% gain in gearing, id like to figure out if 4th gear assist can be disabled as it lands in an awkward spot now. i also lost some low limit regen on decel, which is unfortunate with all the stop and go in my area but all in all this mod helps me enjoy my ride now. i'll upload pics when i get better signal and i will update other side effects and opinions as they arise.
