41 - 48 of 48 Posts
I did the filter change recently (both the cooler line and the main filters), and was disappointed to learn that it didn't have any impact on my jerky starts =(
Still hoping to find a dealer who will give me the non-mandatory software updates, but until then, jerky-jerk.
That said, the operation is pretty easy. It helps that you can drain the pan before taking it off (unlike my old Ford). Be sure to put on a new pan gasket.
What inspired you to bother with dropping the pan, rather than just changing the external in-line filter?
As regards the software updates, I understand wanting to get them for free, but even if you have to spend $100 to get them, it will be the best $100 you ever put into the car (even though it will be annoying knowing that some people got them for free). They dramatically change the driving experience, for the better.
Dude! I would pay $100 in a heartbeat! I couldn't even get my dealer service rep to acknowledge their existence.
Do you happen to have the exact codes? That would make the conversation much easier at the next dealer I try.
Re: dropping the pan, I read somewhere on this board that someone improved the jerkiness by replacing the internal transmission filter, so I dropped the pan so I could do that.
Read this long thread http://www.insightcentral.net/forums/troubleshooting-problems/23191-software-update-installed-my-2010-ex.html. There are several other threads about software update issues, but this is the main one I have used.
Your experience is common. See my post #66 in the linked thread.
Hi ordered online,eBay, as prices here in Ireland are bloody extortionate, saved e15 ,Inc postage
sorry to drag this up again but I am in Ireland as well trying to find CVT fluid for my 2011 insight, is there any chance you remember the brand/model of the transmission oil that you used?
I see the insight ( and the fit/jazz) everywhere these days but there seems to be little online about where to get the transmission oil in Ireland.
Thanks
Alan
There is no reason to use a vacuum pump. The drain plug is easily accessible. Cleaning off the plug is a good idea. If one wants to use a shortcut,
you can refill through the dipstick hole, slowly, with a funnel and maybe a short piece of hose.
Vacuum pump is a fantastic quick clean way of changing oil,I use it 2/3 oil changes and during winter months change the CVT oil with it,ideal for anyone without a garage
I guess that could work sometimes, but I would not recommend using that method exclusively. Draining the sludge and cleaning the magnetic drain bolt should be done.
41 - 48 of 48 Posts
