1 - 12 of 12 Posts
connector?
It was the last bit of wiring John and I couldn't figure out when fixing the ECM wiring in my car.
Thank you heaps and heaps!
Please post pictures of the wires in question.
If the car ever had a cruise control installed and or then removed that could be a possibility.
If it was from a Rostra Cruise Control, the VSS signal is picked up from the blue wire w/white trace in the blue plug at the ECU. IIRC from my recliner, Rostra uses the gray wire and you don’t actually have to use the blue.
Scott
I would have to look to see if it goes anywhere else, but at a minimum, the VSS signal is sent to the ECM, MCM and Instrument cluster. There has to be a junction point or two somewhere.
Yes, please check. I didnt think the OEM wiring used splices, or is what I have non-oem?
There's splices all over in the OEM wiring (I've stripped down an entire chassis worth of wiring). I don't recall there being a gray wire tapped into the VSS line though, the wiring colors are generally consistent for everything. EG: VSS is blue with white throughout the entire chassis.
Well the wire is blue with white stripe, but with little grey hash marks. I didnt know if that was necessary in the description of the wire.
Good to know those types of splices are OEM. This splice is uncovered, should it be taped up or something?
POST A PICTURE OF THE CONNECTION !!
Scott
Not factory, tape it up. Gray hash marks on wire indicated a felt pen identifier by whoever installed the wire.
Discussion Starter #12
Ill be able to tear into it again on monday, Im working through the weekend.
You dont have to help if you dont want, I just like to figure stuff out before I have the time to fix, so that Im productive with my free time.
I also figure if someone else ever goes through the same issues, its here on the forums.
1 - 12 of 12 Posts
