1 - 20 of 22 Posts
Is there a way to quantify the effect my car stereo amp has on my MPG, if any? I have an OBDIICNC with ELD displayed, but I can't resolve the effect of the turning the amp on and off using that data.
Where have you got the amp wired in?
Is the current it's using passing through the ELD?
Unless you are bouncing along the road due to the Bass drawing tens of amps constantly I doubt it has any significant effect.
I have a wire running to the + battery terminal from the amp which is under the passenger seat. My amp has a 15amp fuse so thats my upper limit. The average power will be much lower.
I just realized from reading your comment that the OBDIICNC probably has no way to register the power my amp is pulling.
I'm pretty sure your setup would simply have the amplifier power draw show up as part of the 12V load. So, for example, if you were sitting at a stop light in autostop, pumping some serious bass, you might see Bam fluctuating a tiny bit. I guess if you had, say, a 20watt base load with 100watt peaks, it'd be something like 20w/144V to 100w/144V, or 0.14A to 0.70A Bam blips on top of the rest of the 12V load running at the time (which might be something like 0.5A, or maybe 1A, maybe up to 3.5A if you've got a bunch of stuff running)...
In general, I'm sure there's a way to quantify the 'mpg hit' based on the power the amplifier draws - convert the power to hp, do some other calculations to convert that to fuel economy. Beyond me. But it's probably very very small. I mean, take my 100w example above: 0.7A (off the IMA pack). The car regularly does 7A background charges and it's not very noticeable cruising along. Now divide that impact by 10 and you've got the impact of a 100w amplifier, I guess...
When I have my double DIN radio running (large display lit up) I notice that the +12 volt battery drops a lot faster between charge voltage and no charge voltage, requiring the car to charge it more often, so it obviously take power, and that power ends up coming from gas.
Depending on the type of amp, it may draw a lot of power even when the volume is very low.
The best way is to put an ampmeter and see how much current it is drawing under typical operating levels.
When I have my double DIN radio running I notice that the +12 volt battery drops a lot faster between charge voltage and no charge voltage, requiring the car to charge it more often, so it obviously takes power, and that power ends up coming from gas. Depending on the type of amp, it may draw a lot of power even when the volume is very low....
But you're not implying that that amount of power imposes a... 'substantial' hit to fuel economy, are you? I'm not claiming to be an expert here, nor do I have a great handle on power conversions between electric, gas, etc. Yet, my example of how the car does routine background charges of 7A+, i.e. about 1kW of power, with little noticeable impact on fuel economy, leads me to believe that the fuel economy impact of an audio amplifier, that probably has a lot smaller power draw, would be much less noticeable.
True, in both of these cases there has to be an impact, in an absolute sense, but it wouldn't be noticeable with the typical amplifier (100w, 250w?); it would probably be very difficult to measure even if you tried very hard... It'd actually be kind of interesting if someone could come up with some 'power conversions/equivalents and fuel economy' table: it seems like any 'load', whether electrical or mechanical or whatever - could be converted to horse power or something, and then you could use that to calculate some theoretical impact on fuel economy... Anyone know the formula, the steps to take to get there? It seems similar conceptually to a drag coefficient - so if someone knows how to calculate the loss in fuel economy due to wind resistance - a type of load or drag - then it seems like you could use a similar formula for a fixed load, like electrical power...
[edit] Here's a couple numbers that you'd probably use 'somewhere' to figure out fuel economy impact of 'X' wattage electrical load:
1kW=1.34hp
1.34hp=3.52 pound-feet of torque at 2000 RPMs...
That's all I got. The pound-feet of torque is probably what gets us closer to the actual calculation, as scanning over a couple things, it looks like 'drag' and such are expressed in lbs. Something on this page linked below might help; it has some formulas, explains things, calculating power required for top speed, incorporating air resistance and rolling resistance, and also mentions calculations for fuel consumption. It's not as transparent as it could be, though:
http://www.eng-tips.com/viewthread.cfm?qid=354919
Seems like there might be a really easy, straight-forward calculation, if we started with some known values for the Insight. Like, for example, 1kW=1.34hp, and 1.34hp is X percent of the total power being used; so if you impose a 1kW load (or 100w, or 250w or whatever), it simply represents an X percentage increase in gas power needed to overcome that load - and maybe it's the same percentage increase in fuel consumption, all else being equal?? You'd probably have to choose some conditions to do the calculation, for the impact at say Y speed and Z engine speed, to come up with only one value for those specific conditions. And then you'd need to do a bunch of calculations over varying conditions to get a real estimate... Something like that...
I have a gen 2 and love loud music. If I listen to it in traffic and I will see a force recharge with the ima battery empty and ac wont work til it recharges.
When on the highway no sooner I turn the radio on I see the soc immediate go from 60% to 90%. I cant measure it, but it does seem to have an effect.
I did this pretty lazily, but I like calcs like this so here it goes. Figure the Insight converts gas to electricity roughly as efficiently as a portable generator. The random one I picked had these stats: 14.4h run time to produce 2500W out of 8 gallons of gas. So 2500W * 14.4h / 8 gallons = 4500 Wh/gallon. The Insight may have a substantially different level of efficiency here, but let's figure this is +/- 30% (maybe??) which is probably plenty for our purposes.
Let's figure that you have an accessory that draws 100W average per hour. So it consumes 100 W / 4500 Wh/gal = 0.0222 gal/h. You're averaging 45 mph and 60 mpg in your Insight. 45 mph / 60 mpg = 0.75 gal/h for the car. 0.75 gal/h + 0.0222 gal/h = 0.7722 gal/h for car + accessory. 45 mph / 0.7722 gal/h = 58.27 mpg. You lost 1.73 mpg in this scenario. The slower your average speed or the higher your mpg the bigger the hit.
Nice work. I found this little blurb on wikipedia - which includes a figure similar to yours, -1.7mpg for a 200 watt load:
"Overall, the sources of energy loss in moving a vehicle may be summarized as follows:.... Electrical systems. Headlights, battery charging....[etc.] can significantly increase fuel consumption, as the energy to power these devices causes increased load on the alternator. Since alternators are commonly only 40–60% efficient, the added load from electronics on the engine can be as high as 3 horsepower (2.2 kW) at any speed including idle. In the FTP 75 cycle test, a 200 watt load on the alternator reduces fuel efficiency by 1.7 MPG.(41) Headlights, for example, consume 110 watts on low and up to 240 watts on high. These electrical loads can cause much of the discrepancy between real world and EPA tests, which only include the electrical loads required to run the engine and basic climate control....
"Fuel-efficiency decreases from electrical loads are most pronounced at lower speeds because most electrical loads are constant while engine load increases with speed. So at a lower speed a higher proportion of engine horsepower is used by electrical loads. Hybrid cars see the greatest effect on fuel-efficiency from electrical loads because of this proportional effect...."
Fuel economy in automobiles - Wikipedia, the free encyclopedia
I know that turning the hvac fan on or off affects how often the 12 v charges, and headlights on/off are really noticeable. I assume that my radio is probably drawing 5 amps or so (just a guess, but the display is fairly bright, gps tracking location, etc). Getting 75-80 mpg in the summer there is a noticeable affect driving before dark or after dark. During the day I can very easily keep the ima topped off so it shuts off regen, at night I have to work to keep it topped off. That's without hvac, radio, etc running.
Linsight Designer
I generally agree with the calculations above. I have two nit-picky comments:
-Units are separated from numbers by a space (see ISO 31-0).
-Watts = joules per second, so the sentence "watts per hour" is incorrect; that would be joules per second squared, which is the change in power consumption over time (the difference is the same as velocity is to acceleration).
(I told you they were nit-picky).
I'm generalizing a lot below and can elaborate as requested, but in general:
Today's stereo systems are extremely efficient due to their use of SMPS tracking downconverters and MOSFET output stages. At idle (on, but no sound), most head units pull less than 10 W. Output power increases ten times to double the rms amplitude (i.e. every 3 dB SPL increase requires 2x power, so 6 dB requires 4x power, 9 dB requires 8x power, 12 dB requires 16x power, etc). To overcome the Insight's incredible road noise, the system needs to pump out around 80 dBA, which requires approximately 2 W per channel RMS, so 4 W for a reasonable listening level. If you want to thump thump thump (I don't), you're looking at around 100 dB (500 Wrms) or more. 500 Wrms is 0.67 horsepower, but you won't likely continuously pull anywhere near the amplifier's rated rms power; probably around 20% max rms power.
Lets talk about SPL (sound pressure level). OSHA (USA's ninny patrol) sets standards for continuous sound level exposure. 85 dB is OSHA's maximum work safe SPL without hearing protection. At 90 dB, continuous exposure is limited to 8 hours per day. Every +5 dB above this baseline halves the exposure time (i.e. 95 dB is 4 hours, 100 dB is 2 hours, 105 dB is 1 hour, 110 dB is 30 minutes, 115 dB is 15 minutes, 120 dB is 450 seconds, 125 dB is 225 seconds, etc). These figures use an A weighted slow response measurement (see OSHA 1910.95).
Daily exposure at the above limits will statistically lead to deafness in 40 years, assuming you spend the remainder of the day in silence. Note that sound exposure is cumulative and irreparable, as the sound waves are actually matting down the hair in your inner ear that converts the mechanical wave into an electrical neural impulse. Once the hair is damaged, it never repairs itself.
At 29, I have mild tinnitus in both ears due to my own stupidity with mega base from around 16-20.
I'm all for custom sound installations, but if you must crank the knob to 11 to show off, please consider wearing ear plugs. For the record, I feel old saying this.
Wow mudder, thanks for all this information. I didn't know that about hearing damage. Makes me think that me firing my uncles 9mm with no hearing protection may have damaged me for life. I get random instances where I lose 90% hearing in my right ear and it starts ringing blistering loud.
Dont worry, you are one of us. I like to mumble through my beard when I talk and had a few insight owners ask me to speak up due to their hearing loss. :)
Back in the day many guys had a loss of hearing on one side due to the loud exhaust on the farm tractors back in the day.
Interesting discussion. I have still yet to measure the real-time current draw of my system, but total power is somewhere between 600 and 700 watts. The smiles it puts on my face is totally worth the 1 or 2 mpg hit. I don't crank it up to mirror-shaking volume ALL the time. Only most of the time :D
The tl/dr version of this thread (and my own knowledge of audio systems) is that when listening to *music* and not high db/low frequency sine waves, the actual power averaged out over time being converted into sound is fairly small and will have a very small hit on your MPG. However it is beneficial to run efficient (class D) amps which don't sit there turning electricity into heat.
Agreed. Class G/H amps also- better sound quality with the efficiency benefits of Class D. Downside is they tend to cost a little more.
When I first bought my Insight, I had a 6-channel Class A/B amplifier that I had intended for my Corvette. The Vette's alternator would have handled it just fine but I was not comfortable with it for the Insight.
Going over this thread, this caught my eye.
I've gotten in the habit on long road trips with the Insight of wearing my custom molded "musicians" earplugs which reduce all frequencies of sound by a consistent 15db.
Then I crank the stereo to "11" and all I hear is great music and no road noise!
Those earplugs were one of the best investments I ever made. I wear them out at concerts, in the airplane, and riding my motorcycle, and they're all-day comfortable and don't "muddy" the sound. I can still carry on a conversation and hear the other person clearly.
1 - 20 of 22 Posts
About this Discussion
12 Participants
redeemed763
Honda Insight Forum
Full Forum Listing
