I tried to recreate the problem where the auxiliary starter strains to start, and wont, but I couldnt make it do it tonight.
I had a previous theory that it might help to hold the clutch half way, turn the key all the way, then depress the clutch all the way, somehow delivering a higher voltage to the auxiliary starter and making it function well.
Now, because it is starting strongly everytime, I want to say that the change might have been that by manipulating the 12v battery contacts, and making a better connection, that made the difference to make the auxiliary starter work stronger.
I only saw one ghosty thing, that i couldnt recreate. I have a little cigarette plug voltage meter. and while i was messing w starting it again and again tonight... this one time i saw it sit at a reading of like 11.4volts. I cant remember exactlly what happened, and if i did turn the key when it read 11.4. But i could never make it read low again, and it was always reading like 12.2 with the system all powered up, in the II? key position, where its powered but your not turning it to start. The cigarette outlet voltage meter always reads about .2 lower than what you would see on a multimeter at the battery, is what has seemed to happen in the past.
Cheers yall
Cheers yall
