1 - 3 of 3 Posts
2012 Insight Base
First I'm confused by all the talk of the high beam being used as the DRL at lower voltage. My 2012 uses a plain ole plug in T10 5w bulb. Anyways I swapped the T10's and got the DRL error, I tried adding a resistor , both a 12ohm and 6ohm with no help. I gave up and put the reg bulbs back in and still get a DRL error.
2012 Insight Base
Discussion Starter #2
Ok , I guess was confusing the parking light as the DRL.
1 - 3 of 3 Posts
