hi insighters,.
1. need a pic of the 'A' plug re: ecm, (specifically connectors #23, 24 a solid pink wire, and a blue/w yellow stripe wire.)
2. which wire color for 23, or 24?*
3. ive looked a bit over an hour, but cant find that in the service manual. anyone knows please let me know.
84461
*footnote: the wiring sequence is # right to left, #1 -11 top right, middle row #12-24
t.y.
I don't really understand what you're asking for, but if you got that image from the pdf service manual then you should be able to access the 'connector views', which include a list of numbers and wire colors, from the same manual. The ECM connector views are pdf file IS0006202172A. If you open the index doc, click "ECM power and ground" link, scroll down to the ECM section of the schematic and then click "VIEW 172." Here's a copy of what's listed for connector A:
1 BLU/WHT (STC)
2 BLK/YEL (ENGRDY)
3 ’00-’05: BLU (2WBS)
4 LT GRN/RED (VSV)
5 ’05-’06 M/T: LT BLU (PBRK1)
6 ’00-’05: RED/YEL (PCS)
7 RED/YEL (DVCT)
8 ’05-’06: BLK (MRLY)
9 WHT/GRN (DVC)
10 WHT/RED (M/P MON)
11 ORN
(Late Production ’01:
PO2HTCR)(’02-’06:
PO2HTCR)
12 PNK (IMOLMP)
13 BLU/YEL (IMOEN)
14 Late Production ’01; 02-’06:
RED/WHT (WEN)
15 GRN/YEL (IMOFPR)
16
17 Climate control: RED (ACC)
18 GRN/ORN (MIL)
19 BLU (NEP)
20 BLU/RED (FANC)
21 GRY (K-LINE)
22 ’05-’06 M/T: LT BLU (PBRK2)
23 BRN/YEL (HTRS)
24 BLU/ORN (STS)
25 RED (IMOCD)
26 ’05-’06: BLK/RED (IG1)
27 Climate control: BLU/BLK
(ACS)
28 CVT: YEL/GRN (SLC)
29 LT GRN (PTANK)
30 GRN/RED (EL)
31 CVT: WHT (IDSSW)
32 GRN/WHT (BKSW)
^ I attached that page since I just found it.
Related subject: I need to access the ECM too, on my RHD car. Before I start blindly pulling the carpets up, is it on the same side as a LHD car, i.e. LHD passenger side (= driver's side on a RHD car, which would be up behind the pedals)? Or is it switched sides and on my passenger side?
thank you eq1, jonny69, n' reptep....yeah, that's what i needed...that plug with the pinouts.
re:manual, for some reason, my pdf man, does not have "ECM power and ground" link, in the index, yet does have all the pdf files like IS0006202172A. but without any links to those isos, there kjnda useless.
