Hi Originalbadbob:
___If you live in California, Maine, Massachusetts, New York, or Vermont, I believe all of your gasoline is low sulfur. I know it is in California anyway. If you live in upper Wisconsin or Minnesota, you can find LS gasoline at any Super America promoting Blue Planet fuel. In most larger cities around the country, you can fill up with LS fuel by purchasing Amoco Ultimate Premium brand gasoline. It is ~ $0.20 more/gallon given it is 91 Octane Premium but it is also low sulfur. Check with your local station to see the invoice if the attendant does not know. The “LS” designation will stand out quite clearly amongst the rest of the gobbily **** on those things. I saw a delivery invoice for an Amoco station in Braidwood, IL. and it listed one of the tanks being filled with LS. This is the Premium Ultimate you might have seen on TV. Make sure however because I don’t think it has to be LS, but just is in some of the larger metropolitan areas IIRC. With a bit of searching over at BP, I bet you will be able to find what you need?
___I hope this helped.
___Good Luck
___Wayne R. Gerdes
___[email:amdms6ww]
[email protected][/email:amdms6ww]
