I bought a DRL module that I am planning to install in my Insight. The following link displays the installation instructions for the module. (Sorry, it's kind of large for readability)
DRL Instructions
The question I have relates to the Final Wire Connection section. It talks about wrapping the green wire around a spark plug wire or hard wiring into the "oil pressure switch or a high point 12 volt source when the ignition is in the run position" to control when the lights are actually on.
I figure that if I use the spark plug wire method, the lights will shut off during auto-stop (correct?).
Can anyone with an electrical manual or knowledge point out a 12v source as described above?
Thanks!
DRL Instructions
Thanks!
