G
Guest
·Guest
Reading thru the threads, its generally clear that charging the IMA battery directly is bad because the computer doesn't understand where the extra charge came from and it causes Recal's, etc.
My questions are these:
What if you instead provided a charge (from whatever source... that's a different issue) and your point of connection was spliced into the conductors of one of the regen systems (brakes, transmission)?
Wouldn't it 'fool' the system into thinking it was getting the charge from the inductive system and charge the IMA battery in an acceptable manner?
A possible requirement would be that the electrical system of the car was on.
It might be required to fake the car out that a regen system is 'active' (when its not, if I recall correctly... someone did this with the brake system).
