You realize that the powering up the BCM will draw off the 12V battery. So you need to provide
12V as well 144V for this to work. Also, double check the schematics because you'll want to make sure that there is power for the battery cooling fans which are controlled by the BCM.
IMHO, you probably can get by with a knowledgable operator who can read the SOC and then set a timer on the charger. Also, if you charge at like 10ma, you probably can't harm the battery pack by over charging.
