Hey everyone, I want to get an engine block heater for my insight but can't seem to find one that would fit my 2005 cvt insight. I found one on Honda parts now that fits a 2003 cvt. Do you think this would fit or work?
Pretty sure there were no changes in the block between between 03 and 05. I checked Majestic for Honda block part # for the two years and they have same number. They would be different if the drain plugs were different. If the part fits the 2003 then it should fit the 2005.
You can always send it back if it is wrong.
Here's what I bought and installed on 2 different Insights. Cord is longer. I rolled up a 2 coils and zip tied it to the ABS lines. Left enough to feed it through beside the radiator, under the top rad support with the end tucking into the opening where you reach to open/close the hood. My cars are both manuals, 2000, 2001.
