1 - 2 of 2 Posts
Hello all.
This AM i was checking on my air filter and i forgotten to plug-in the air filter sensor cable after completed. After start my engine, the engine light and VSA light keep illuminated with intermittent Check emission, VSA and brake system appear on MID.
How do i reset the warning without connecting OBD scanner (like disconnect battery terminal)? Currently I'm away from the town.
Is it safe to drive with warning light illuminated?
Thank you.
@lee757
Disconnect the negative battery cable under the hood at 2-5 min.
The errors will be reset.
Please, note that, you may need a security code for your radio.
If the errors appear again, you need to look at the ODB-scanner.
Without ODB-scanner, use the service manual, you can test it like this:
1 - 2 of 2 Posts
About this Discussion
1 Reply
2 Participants
gms24ru
Honda Insight Forum
Full Forum Listing
