1 - 10 of 10 Posts
I got the manual for the Insight. I have 2000 5spd model. I need to pull the transmission and replace input shaft bearing (most likely I think) and the manual has a special tool called an engine support hanger.
Where do I get one of these? I am wondering if the Insight owners here might have ne that floats around from owner to owner? I imagine once you have used it, you don't really have much call for it again...
Anyone have any tips on that?
AND - anyone that has done the trans work on this, any helpful tips or caution points would be great. Especially if you have done this bearing job.
Thanks!
Hanger would be nice, but not absolutely necessary
Just finished getting mine back together after doing the ISB and synchronizer mod. I put the car up on stands (see post number one http://www.insightcentral.net/forums/modifications-technical-issues/25102-just-feeling-silly.html ).
I used a car scissors jack with a rubber pad on it to support the engine, and didn't have a problem. Guess an engine hanger would have been nice. Just be careful, the oil pan is made of magnesium.
I did use some help re-installing; see post #64 on the following link.
http://www.insightcentral.net/forum...-speed-input-shaft-bearing-replacement-7.html
Hope this helps,
Tim Glover
Discussion Starter · #7 ·
Oh I see the other poster gave a link. But I am not having any trouble with shifting at all...and I don't use a clutch, so if there was an issue I would surely notice...don't you think?
Read Only
If you're shifting without using the clutch, then you must be rev-matching which accomplishes what the synchronizers would normally do. Therefore, the synchronizers wouldn't be used which would avoid exposing the 1-2 synchronizer design problem.
OK..you never responded on what the synchronizer mod is...
Puzzled here. Willie posed this link http://www.insightcentral.net/forum...01-gen1-transmission-problems.html#post260838 . Also the synchronizer mod is listed earlier in the link I put in my previous post. http://www.insightcentral.net/forum...-speed-input-shaft-bearing-replacement-7.html
Essentially, it is simply grinding off the clocking tabs off the 1-2 synchronizer rings. This stops the dreaded grind when downshifting from third to second, and also from second to first.
My 0.02 worth,
Tim Glover
1 - 10 of 10 Posts
