Recently I turned my Insight off. When I got back in the EPS light was on and the power steering was not working. I have checked all the connections to it and all the grounds and 12 volt system connections. I checked the fuse and all seems ok but the EPS still is not working. Any ideas on what I should check out?
Have you driven the car like that?
I've seen this before but the EPS light turned off and the power steering started working after driving the car for a few seconds.
Been driving it that way for a few weeks. I like it with no EPS when moving but not at low speeds. I don't think it is going to start back on its own.
I am pretty sure that it is the little ground wire between the EPS and the firewall. Like all other ground on the insight, it get corroded ans fall apart.
