1 - 7 of 7 Posts
It would be really nice to have a switch to engage EV mode for the Insight. The switch would basically emulate very light pressing of the throttle pedal to activate the Hybrid Battery consumption mode, where only the NiMH battery is used to propel the vehicle.
I often use this mode going down hills when the battery is already charged or for Pulse and Glide techniques on flat roads.
Any ideas Modding Community?
Basically you want MIMA or IMAC&C for the G2. Lot's of people do. ;)
Unfortunately no one has done the necessary research to do that yet.
I offered to do it some time ago if the community provided me with a G2 Insight to do the work on. Unsurprisingly that never worked out.
You need a G2 $$££, the time, equipment and skills to do the work.
I haven't got a car and won't have the time for at least 18 months to have a look at it.
The G2 uses CAN comms and the difficulty in implementing a control system is much higher than the G1 or HCH1 Civic.
Theres more than one way to skin a cat. My idea was to make a FAS switch to kill the injectors by the yellow/black wires. For EV mode you would push and hold this button while giving throttle. It should work in theory. :D
In my experience I think the ima battery is just too small to do that and I use to have a phev kit back feeding it 117 volts and 17 amps. I got a mile and half before it pooped out when combined with a fully charged ima battery.
idea for EV mode
Hi New to the forum and Gen 2 insight, but rather than full EV mode I had wondered if it was possible to fool the car into thinking that the brake is lightly pressed, to trigger pure regen braking. has anyone encountered where the brake on is fed to the various control units, and if there is an analogue as well as digital brake light feed?
I actually wanted the same thing for my I2 ...
I have EV mode on my CT200h. I mean it's nice having the option and all, but, I can basically enter EV mode with modulation of the gas pedal on demand. Especially after having drove the Insight, it's totally easy for me because you had to be real particular with pedal modulation on the I2 to enter EV mode.
Being able to trigger full regen, let's say I'm coasting down the other side of a hill, and get maximum regen while doing it without touching the brake pedal would be SUPREME on an I2.
I really don't think the brake pads / shoes actually engage if you barely touch the brake pedal, so, your thinking might have something to it.
If we had not had one of the four front pads sticking, they would have lasted to 80 k at least. The three that were not worn and came off at 60 k were only half worn. So I do think you are right, the pads don't engage until the final phase of a typical stop and probably not at all when just slowing down.
The pads on my Insight lasted until either 150 or 160k miles.
I *think* the front left caliper had begun wearing out because the front right pads still had decent life left.
Kinda funny you can have a car and worry about the life of the calipers, arguably more, than the pads ... lol
And I reused the rotors. LOL
Definitely grooved out well though, should probably have replaced them, but, I didn't have any pedal pulsation issues or vibration of any sort when braking, so.
1 - 7 of 7 Posts
