As far as RBbatteries go, have you emailed or call them? I found them to be extremely responsive to concerns and questions. Unless there is some completely esoteric purpose it seems to me just to be another way to monitor your gas mileage.
As far as RBbatteries go, have you emailed or call them? I found them to be extremely responsive to concerns and questions. Unless there is some completely esoteric purpose it seems to me just to be another way to monitor your gas mileage.Can somebody explain what the FCD button does pls.
also, when is rbbatteries restocking. Website says the 25 but it’s now the 27th.
I emailed them twice on different occasions and nothing. I can’t find the phone number.
Yeah I confused because once I press it q different mpg comes up.
I didn't know this. Thanks!Pro tip 2: you can press and hold FCD when in trip mode (only when stopped or before trips or something like that) to page through the elements in the display that are or are not displayed. For example, you can remove the instantaneous fuel economy bars from the display that shows total, average, and bars, so only the total and average remain.
Funny - I was thinking you were the one who pointed out that you can only do that when you have your foot on the brake - or something like that. The car has to be stopped, at least, I think...I didn't know this. Thanks!
Back when my state required inspections, the testing facility had a strict "you must leave the car so we can test it" policy. I always loved watching them search (in vain) for the OBDII port. A couple times in TX they ended up just using the pre-OBDII tester (i.e. tailpipe emissions).I thought the FCD button was to confuse service writers at the dealership!
Here, too, they saw so few of them I was asked several times if it was "electric."Back when my state required inspections, the testing facility had a strict "you must leave the car so we can test it" policy. I always loved watching them search (in vain) for the OBDII port. A couple times in TX they ended up just using the pre-OBDII tester (i.e. tailpipe emissions).
fyi, segment display has a double-headed arrow at the top of the display....The segment display has arrows at the ends of the little bars or something like that.
You can remove the instantaneous, and you can remove the instantaneous and the average - so that only total remains. You can't remove the total. So it's like, press and hold, instantaneous disappears, press and hold again average disappears, press and hold again and everything comes back. Also, I did this merely with the car stopped, so you don't have to do it 'before a trip' or when you first turn the car on, etc. I didn't check whether you can do it with the car moving, but in the past someone said you can't do that...Pro tip 2... you can remove the instantaneous fuel economy bars from the display that shows total, average, and bars, so only the total and average remain.
