Temperature will play a noticable factor too. Should be easy enough to try it for yourself.
If you did the more conventional reset (disconnect then reconnect the 12v to force an IMA recharge to full) it varies based on the beginning SoC and temperature. Usually 3-4 minutes is sufficient.
IIRC there have been credible posts that if done with a beginning high SoC the time factor is shorter.
