1 - 2 of 2 Posts
Hey everyone...
I was wondering if anyone has any info for the Fram SureDRAIN oil drain plug replacement. When referring to Fram's parts catalog book (in store not online), it said the SD-2 (M14x1.5 thread size) model fits the Insight. However, if I recall correctly, someone on the Yahoo groups forums posted something about the thread size being slightly too large (or was it small?). Anyone else give this product a try?
Also, I believe some people here were interested in finding easier ways to remove the oil filter. If you don't want to spend too much, Walmart sells a 3/8" drive type wrench that fits the Insight for under three bucks. It's a plastic type wrench with a metal drive insert. The brand of it is "Stride Tool" and it's the "Type B" size. Sure beats the price that Honda wants for their hex nut wrench (>$20 bucks).
I installed the 14mm. Fram quick drain about 10,000 miles ago. The results have been excellent. I can now change my oil (every other time) without putting the car up on ramps.
I just take an empty gallon jug, lay it sideways on the ground and screw the hose on to the oil pan. fitting. The Fram quick drain does need a cable tie to keep it cannected to the nipple fitting.
Apparently my Insight drinks a little more than a half quart every 7,500 miles or maybe its just left in the filter. I have 61,00 miles on my car.
As for removing the filter, I found that a strap wrench works fine.
1 - 2 of 2 Posts
