Hi All,
The vent mod is finally done and I’m just sitting here waiting for hurricane Frances to blow past (storm prep done). I mod’d my horn some time ago and this would probly be a good time to share it. I wanted to leave the stock horn intact and add a second horn to compliment it. I had pulled out the under hood fuse panel assembly. Wouldn’t want to tap off the wire that goes to the stock horn, looks to me like it’s 28 gauge (real thin). If you look in the fuse panel at the relay you’ll note that there are two other relays (same part #) just to the side of it. Those two others use 15 amp fuses so I guess…their rated for at least 15 amps. So first I changed the 10 amp fuse for the horn to a 15.
So I decided to tap off the 12vdc to horn signal. For a horn I chose the “Freeway Blaster” available at Advance Auto Parts and probly Auto Zone too (cost about $10). Chose the 132 decibel Low Tone to compliment the meep-meep horn. Mounted the horn close to the fuse panel, used the bolt for the drivers end or the cross bar and the mounting bracket that comes with the horn (had to drill/enlarge the hole in the bracket a little so the bolt would go thru.
Next pulled out the horn relay. The socket connector for the horn signal is the one in the center. Removed some of the socket wall (on the passenger side) so I could run a 12 or 14 gauge wire in and insert the bare end into that connector (like a fuse tap). I used a red wire (about 14” long). The other end I ran neatly to the horn and connected it to the horn with a standard insulated female bayonet connector (you can connect it to either connector on the horn, doesn’t matter). The short wire that comes with the horn I put on the other connector. The other end of the short wire has a hole connector which you can stick under the cross bar bolt (see pics). Made red wire neat with a couple of wire ties
and Wa-La, done. Want to get peoples attention? You can now. A nice easy fun mod where I don’t get chased around dealerships or parking lots. About ½ hour shopping,
½ hr staring at engine compartment and ½ hr for install. Enjoy your ride, Jack When you get to the URL click on NEWEST to view horn mod pics...
http://community.webshots.com/user/jackmpg
